Factory FE2 springs are soft as, even when brand new they fell short of the spring rate that Holden specifies. No doubt, second hand ones will be even softer (and lower, due to sag). Because of that, springs from the likes of King Springs built to the FE2 specification are a fair bit stiffer than factory FE2 springs. If I remember correctly the springs fitted to the sports HSV models (e.g. Clubsport, GTS) are stiffer and slightly lower than FE2. Not sure how the senator differs but I very much doubt it is any softer than FE2.
There is some good info on the actual spring rates of various aftermarket springs here:
King Spring Info
This is my car on King Springs 'Low Heavy Duty' (KHFL47HD and KHRL45HD) and KYB Excel-G shocks.
http://farm9.staticflickr.com/8503/8439824789_1fa17c4f3e_b.jpg
http://farm9.staticflickr.com/8186/8434654868_93d4808c0b_b.jpg
It sits about 15mm lower than FE2 in the front and about 20mm lower in the rear as compared to another VY V6 with factory FE2. It is quite a bit stiffer than FE2. The step up in stiffness from FE2 to what I have is almost as significant as going from FE1 to FE2. Ride quality would be totally unacceptable to the average person. I still have FE1 swaybars front and rear, handling tends towards oversteer at low speeds (<40kmh) neutral at about 60kmh and slight understeer at speed (>80kmh). I would upgrade the front swaybar first and then decide if upgrading the rear is necessary. From what I hear, you want the softer adjustable front bar that Whiteline sell. The extra heavy duty one is too stiff for street use. A decent strut brace is probably also a good idea (not the factory one, they are as good as useless) - it won't make a significant change to handling, but it will help prevent cracking the seams on the strut towers due to having stiff suspension.
