DeveloperChris
- Feb 15, 2009
- 4
- 0
- 1
- VY series II Berlina
I am replacing the water pump on my v6 commodore and find a significant amount of oil on the water pump to head bolts on the right hand side.
When removing the bolts they were covered in oil. When I removed the bolts completely water streamed out of the holes. I had just flushed the engine so the water was clean. When I removed the top bolt the oil literally dripped off it.
After copious amounts of searching I could find no-one talking about these bolts having oil on them and could find no video's with enough detail to see if this is normal or not.
There is no evidence of oil in the water pump.
It occurred to me there may be a blown gasket on the timing cover.
Is that a possibility, should I be stripping off the timing chain cover? Or do these bolts go into an oil channel and this is just normal?
I have attached a couple of pictures showing the worst bolt and the bolt holes.
