VY Cruise Control Patch
Ozkruz
2004 VY Cab Chassis
I have done a heap of researching on the threads to do with Cruise Loom Patch, or adding Cruise to non cruise cars.
I have a 2004 V6 VY Cab Chassis that has no cruise, I have bought the module, brake switch and changed out the stalk. My engine loom has no plug in the engine bay so I am looking at the cruise patch kits.
from everything I have read, I can use a V8 patch loom and change out one of the plugs. I just want to confirm that is correct (I can source a V8 patch loom kit) and for someone to confirm which plug needs swapping out (says it is a quick change)
I am assuming the patch kits have the wiring from the stalk and the brake switches as well.
I can’t source a V6 patch loom for the cruise anywhere, well so far anyway
Cheers,
Trevor loves holden.
vs commodore
If you don't have the plugs ready to go I say you have to change your pcm, don't know though just a hunch..
Ozkruz
2004 VY Cab Chassis
Fr
Thanks for the reply, I had read that thread but it didn’t really answer what I was looking for. I don’t believe I have to change the PCM as the patch looms address the missing plugs and the module is still ok even on the base versions.
After a lot of trawling there is one reply that says the V8 patch looms are the same, except one plug and I believe it is the one that plugs into the cruise module.
Supposedly this plug can be swapped out easily
Ozkruz
2004 VY Cab Chassis
Thanks, that is the one I was looking at and I didn’t want to buy it if it wasn’t going to work
vs commodore
There a few on ebay with complete cars selling Cruise module just ask them for the patch lead. Good luck.
