holdencple
- Oct 11, 2009
- 42
- 0
- 6
- 2005 VZ SS 5.7L LS1
For those wanting to do it the easy way without unhooking the battery and fooling around with the ABS module then using electrical tape to seal it back up.
here it is : located at the firewall passenger side is the traction control unit unplug the conector plug with the blue top, tie it off out of the way and your done,no traction control and easy to connect back up when needed![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
May not be usable on all Commodores :- this has been used on a 2001 VX Clubsport and a 2004 series 2 VY SV8 LS1 without any error codes coming up not sure what other models this will suit.
Pretty sure your able to do this with all ls1 engines.
refer to pictures attached.
![engine.jpg engine.jpg](https://forums.justcommodores.com.au/data/attachments/54/54530-0ca44c1603db6da40f129fee67d6ab66.jpg)
![engine2.jpg engine2.jpg](https://forums.justcommodores.com.au/data/attachments/54/54531-e6c4f2dd45515ec5ee48539203171e35.jpg)
