VY Ecotec conversion worth doing?
triple b
VS Commodore
Hey guys, just wondering how much it costs to swap to an ecotec from a VY into a VS?
Is it worth doing?
Do i need to find a manual VY ECU to go with my t5 or can i just use my existing ECU?
Rough costs?
FstStig
Diagnostician
Central Coast, NSW
2010 VE SV6
Should be a fairly straight swap, just make sure you get your wiring harness and you will probably need to modify a few things such as your EGR Valve and your Coolant temp sender/sensor as they are one on the VY's. You may need to get the VY ecu and have it programmed for your Manual, shouldn't be to much of a hassle other wise.
Z2TT
VL Commodore
Why do you want to take an ECOTEC out and put the same motor back in?
Are you after a lower K motor ?
triple b
VS Commodore
Yeah im after a motor with lower K's. I think my rear main seal has gone (will look tomoro) and figured if i gotta take the motor out to fix that then i will look into a VY ecotec if its worth doing
clubsport-r8
Central Coast
VS V6, VZ Clubsport R8
& the VY ecotec has 5kw stock then a VS Ecotec lol, you would be better off just finding a low KM engine from a VS, straight swap without messing around with wiring harnesses, or sensors.
I would only go the VY Ecotec if I couldn't source a low KM VS Ecotec but that is just IMO.
Burnout124
Western Australia
VY Executive S2/ VY SS 6sp
you can use the vy motor just put your vs manafold on it and you wont have to worry about sensors or the ecu
Decicrate
BrisVagus
VS L67
triple b
VS Commodore
Originally Posted by nathanVS View Post
L67 instead, easier
+1 best bang for buck you can get.
Slight isssue, still on my P's :( Another 2 bloody years
