YellowSticker
- Oct 16, 2021
- 11
- 2
- 3
- Age
- 31
- Location
- WA
- VT Commodore
Are the flywheels on these 3.8L ecotec engines balanced to the torque converters?
My 1999 VT 3.8L Ecotec engine **** itself and I replaced it with an Ecotech from a 2003 VY.
Both engines say LN3 on the respective VIN identification plate.
I removed my engine at the gearbox housing, so those bolts and the 3 flywheel (?? flexplate?) bolts are all I dealt with when I put the new VY engine in.
I noticed the inspection covers are different, I had to use the VY ones but they still covered my VT gearbox just fine.
The guy I got the engine off asked if I aligned the torque converter up and I said I didn't think so. The starter motor makes a clunk when it starts (that's how he could tell).
He said something about 2 weights that need to be at 180 deg of each other. He said to remove the 3 bolts on the flywheel through the inspection cover, rotate the position and see if it clunks on start up.
He said if the starter motor clunks STILL after all 3 positions on the flywheel have been tried - i will have to remove the torque converter off my old motor and do the same thing.
I read a lot about marking the flywheel and **** to keep balance when reinstalling engine but because I was doing an engine transplant (ie. Not using the exact same motor), my repair manual doesn't say jack **** about what to do in that case. So I just bolted it on.
I have read somewhere now that the counter weights that balance the VY engine to the VY gearbox may not be present, or are different, to the VT engine and gearbox.
I'm guessing that means I will need to remove the torque converter from my VT engine and install it onto the VY engine to use my gearbox? OR I will have to use the VY gearbox that came with the engine. Which is a whole new set of issues because I like my VT auto gearbox.
Does anyone know if that is the case? The VY gearbox says 3HFD. No idea what my VT one says.
Other than the clunk the starter motor makes when I start the car, is there another way to check the engine and gearbox are balanced?
