troyz0r
- Jun 9, 2013
- 3
- 0
- 0
- Location
- Burn City
- VP Berlina VN Calais
Long time lurker, first time poster. If you guys can be half as helpful to me as you have been on the plethora of other threads I've found and used on here before, I'll be ecstatic!
Lately the missus' car - VY Exec - has been making a sorta grinding/squeaking sound coming from the front wheels (or I thought it was just the LHF, turns out to be both)
Had it up on stands today, I was rotating the passenger brake disc and I could see and feel that it was grabbing on the pad every 1/3 or so of a revolution. I've searched pretty thoroughly and have sort of come to the conclusion that it's a little warped, however I've also read that they supposedly tend to go a little off if the wheel nuts are done up too tight. Now let me tell you, they were so tight that the wheelbrace held my weight (85ish kilos), so I'm not entirely sure what the issue is there.
I checked the drivers side, just for my own peace of mind really, and found that it was a lot harder to spin than the other side, like someone was lightly putting the brakes on. Also, on the 9 o'clock - 3 o'clock axis, they move back and forth a good 10mm, maybe even more. There's no play in the 12-6 axis, only 9-3. This is with everything (caliper, etc) still bolted on. All I removed on both sides were the wheels as it was just a quick visual inspection between other things I was doing.
I'm sure it's an easy fix, but I don't like taking chances with brakes, and I don't particularly wanna see the missus wrapped around a tree cause of them.
I tried to explain it all as clear as possible, so if anyone could shed some light, that'd be awesome.
