Vy exhaust.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Do not go twin on a stock V6. That system won't fit anyway.
If it is just noise you want, the I can supply you with a 2 1/2" cat back Manta system for $260. If you want it louder I can do one without a resonator for $220.
If it is performance you are after, then fit extractors, leave the standard size but replace the mufflers with straight through glass packed items.
linkenator
perth
vy commodore
thankyou for the information.
sorry but i forgot to outline my other plans for purchases:
1: stage 3 comp cam with retainers and pushrods to suit.
2.mace 25mm manifold insulator, 69mm throttle body, 82 degree thermostat.
3.otrcai. extractors of some description.
thanks any other info is ,much appreciated.
i also need information about extractors which would bolt up to the factory cats
i am handy with a welder if i have to
nate-vy
blown vy v8 ute
if your handy with a welder then you wont have a problem ...
is yours a single cat or dual cat ...
either way its quite a simple job that i have done myself with limited welding knowledge
