VY Glove Box Light
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Jess89, Dec 15, 2008.
  1. Jess89
    Jess89 ~ BeachBabe ~
    VY Ute
    Can anyone tell me how i can make the light in my centre console work? just installed it and its not working! Everything seems to be plugged in the right spots and the cig lighter is working, how come not the light...?
  2. gottavecalaisv
    gottavecalaisv Member
    2013 Vf SV6 Jungle Fever
    check to see if you have power with a test light, if you do then the globe is blown if you don't then it is in the wiring or the switch.
  3. Jess89
    VY Ute
    no power, could it be a fuse because wiring is pretty straight forward, only two wires? or is there a catch!?
  4. gottavecalaisv
    one will be power and the other will be earth, check the fuse, if it is not blown then it is your wiring.
  5. Jess89
    VY Ute
    ok so which colour is the earth wire?
