VY Hand brake adjustment
jimbo39aus
Nowra NSW
VY11 Executive ex Cop
VY hand brake
You gotta remove the rear rotors to adjust the hand brake on the VY i'm told.
I just booked my VY in for it's 90k service and they told me that it is a major service and part of it is to remove the rear rotors to adjust the hand brake...
I'm guessing there is a shoe adjustment in there to play with...
Hope this helps...
R
red131
Guest
hand brake adjustment
To adjust the VY park brake you need to remove the rear brake rotors and adjust your pads out, or a quik adjustment can be made to the park brake handle and cable by pulling up the rubber boot around your handle and tightening up the adjusting nut for this you will need a 7/16 tube socket this will give you some adjustment if theres only minor wear and stretch i on your pads and cable.
