2005vzute
Djabringyagrogalong
- May 26, 2010
- 362
- 3
- 0
- Age
- 30
- Location
- Glenfield 2167
- Website
- forums.justcommodores.com.au
- 2005 VZ Ute M6
g'day all,
I've attempted to properly adjust my parents VY acclaim handbrake...i've jacked the car up..backed off the nut at the lever, took the rear wheels off..took the rubber grommet out of the rotor and adjusted the right side shoes using the toothed wheel..done and dusted within 10-20 mins...however..when i tried to do the same thing to the left hand side, the toothed wheel wouldn't budge at all...so i took the caliper and rotor off and had a look...i tried to turn the toothed wheel where i could properly see..it still wouldn't turn...i had a look at the mechanism which makes the shoes move in and out..i have no idea how the toothed wheel is meant to adjust how far the shoes stay from the inside of the rotor...im not sure if its a wrong part that's been put in there but im assuming all handbrake adjustments done before on this car were done straight at the lever because there is verrrryy little thread for the nut to screw down anymore...anyway, the point i was getting to is that i see no way in which this toothed wheel adjusts the shoes in and out when i try to turn it..there no threads or anything that i could see...hence why im thining there could be a wrong part in the mechanism...now that i have one wheel adjusted correctly and the other side still slack, the car slouches to one side when the handbrake is on...i need as much information or diagrams and pictures as possbile....however, im greatful for any help given =)
cheers guys
cheers guys
