VY Heater Noise
1997 vt
vz sv6
hi i have a vy belåna with climate control lately i am hearing a rushing water noise coming from some where under the dash i have looked everywhere and cannot find where its coming from i am not losing water from the radiator the carpet is not wet yet the sound continues i have asked many mechanics no one knows what it is it really sounds like i have water in the plenum chamber where the wiper motor is but i have checked this and it is also dry i am stumped if anyone can help it would be greatly appreciated
cheers Paul
Trevor loves holden.
vs commodore
Vacuum leak? A/C pipe drainage? A/C running low on gas?
PlenumBiscuit
VY Commodore
You have air bubbles in your coolant maybe. Bleed your coolant from your radiator
krusing
Melbourne, Bayside
Im tipping its low on water, and/or air in the radiator coolant through the heater,
try bleeding the system, [remember to turn your heater on to let the water flow through the heater tap that is below the Master cylinder plumbing.
I think there is a couple of bleed valves on the V6's [assuming its a V6],
Where there is 3 bleed valves on a Supercharged V6, and I have all 3 of them open to get the air out of the system.
