mikevy
- Feb 16, 2017
- 3
- 0
- 1
- Age
- 28
- Location
- Brisbane
- VY V6
Hey guys, today after I replaced my clock spring (SRS Airbag fault issue), I noticed my horn has stopped working. Prior to changing the clock spring it was fine, so I'm assuming something went wrong with the clock spring replacement.
I thought I might've had the steering wheel controls mixed up with the horn plug, so I swapped them over, and after that, pressing "volume down" would successfully activate my horn... So I swapped it back (the steering wheel controls work in this config) Which tells me the horn works & it's most likely not a fuse issue.
Any ideas? I opened the steering wheel up and manually connected the two plugs for horn (with the battery connected) and it still wouldn't activate, so I don't think it's an issue with the horn pad.
Cheers.
Cheers.
