zanolomas
hi I have a 04 vy sII and the horn does not work at the button the fuse is fine and relay had a second hand clock spring put in out of a vx. the horn worked in that if I join the pins before the clock spring the horn goes of but then I reconnect the clock spring and try joining the horn wires under the airbag it wont go off any one no what the go is. I replaced the clock spring because the srs light is on and I still need to put it on the scan tool tomorrow at the mechanics to reset it. would this be why the horn wont work? last time it was on the scan it said drivers air bag resistance to high so though it might be the clock spring
