krusing
- Jun 21, 2014
- 5,403
- 4,036
- 113
- Location
- Melbourne, Bayside
- 2002 VY L67 Calais Sedan, 2012 VE L77 Calais Wagon
Dear JC Members,
Are you having premature Lower Cooling/Radiator Hose Failure?
I was recently flushing the cooling system, and found that the Lower cooling hose was rubbing against the Front Radial Arm Bracket when the engine was up to Temp/Hot, [after running it, and bleeding it]
It was that close, I wasn’t able to slide a Credit Card between the Hose and Front Radial Arm Bracket,
I sort of figured best to get a new Lower Radiator Hose, as its probably damaged from the edge of the bracket, and it will fail at the worst possible time.
So, I removed and Modify the Radial Arm Front Bush Bracket with a Cutting Blade, then
Grinding Blade, and finished it off with a file [Flat Cross Cut Bastard]
Knowing the OEM Brackets are rolled over the frame, I guess that is why, not to foul the Lower Radiator Hose pass over the top of the subframe.
I have attached a few photo’s before and after.
The little man in the Yellow Van, will love you for carrying Spares for these type of breakdowns.
PS: I was a fan of worm-screw hose clamps, but in this case, I used the OEM’s,
as they keep the tension on the hose when they heat up and become soft/malleable,
I also placed some gasket cement on the inside of the hose before I slipped both ends on, to make sure it seals at both ends, on the block, and on the Lower radiator fitting.
- Hose showing Clearance when Engine Cold
- Modified Radial Arm Front Bracket
- Modified Radial Arm Front Bracket [different angle]
- Radial Arm Front Bracket re-fitted showing new clearance with old hose
- Radial Arm Front Bracket re-fitted showing modification
- New Lower Radiator Hose Fitted
- New Lower Radiator Hose Fitted showing the clearance between the New Hose and the Front Radial Arm Bracket
- Radiator re-fill Container, perfect Fit, Head of Water to Bleed the L36's & L67's 3 x Bleed Screws
- Old Hose Removed, ok for a Spare ["Straight to the Spare Wheel Well']
- Old Hose's and Belts tucked away in the Spare Wheel Well.
08 L67 Radiator Head Of Water Container to Bleed the system.jpg81.9 KB · Views: 88
10 Old Hoses Straight to the Spare Wheel Well with the Old Drive Belts..jpg82 KB · Views: 88
