vy l67 conversion guide help
killya15
Australia
holden vr and vy
can any one help me ive looked through this forum and cant find any guides for a vy.
so what i want to do is put a l67 in a holden vy s, so what do i need apart from engine and box do i need to use my vy loom or the vt one, chop and change vt loom?
Futech
Like a boss
Auckland, New Zealand
VY 5.7
You will need to use the VY loom, PCM, BCM, Cluster etc and wire that to the other engine. Im pretty sure its the same engine in both but you don't want to use VT wiring etc as you will not get things talking to each other. The biggest issue is conflicts with the cluster. Reprogramming will have to be done. So what im saying is if you can plug and play your existing VY loom into that engine and it all fits e.g plugs etc then your good to go. If not your going to have a lot of fun. And i don't advise cutting and wiring as thats just going to open a big can of worms for you.
