krusing
- Jun 21, 2014
- 5,403
- 4,035
- 113
- Location
- Melbourne, Bayside
- 2002 VY L67 Calais Sedan, 2012 VE L77 Calais Wagon
Which makes me think fuel/air/mix delivery control issue.
Isn't that what changes most when ECU gets higher temperature sensor readings from cold?
And the occurrence utterly predictable with the only variable being engine temperature (therefore more likely to be choke/mix related than spark/timing)?
Very True,
but everything is clean as I can get it.
I forgot to mention, I did also take the Temp Sender out of the same vehicle I got the IAC & TPS units from,
and still have exact same flat spot scenario.
But it only faults for no more then 3 minutes, which is the time it takes to get the traffic lights up the road, after that, it runs great.
May have to do a Live Data screen on the Autel unit and see if there is any thing obvious,
Or just take to a guy with a Dyno, and let them put it through its paces when cold.
