Idle relearn Long Method from HSV forums
Idle Learn Procedure...IAW Holden Workshop Manual [Archive] - HSV Forum
This needs to be done after disconnecting the Battery or doing such tasks as Throttle body Cleaning etc...
The Information is from Holdens Workshop Manual:
Automatic Transmission:
1. Ignition Off
2. Restore PCM Battery Feed
3. Turn OFF the A/C Control (if fitted)
4. Set Park Brake and chock road wheels.
5. Run engine at Idle
6. Shift transmission to D (drive)
7. Allow engine to Idle for 10 Minutes.
8. Turn ON A/C controls
9. Allow engine to idle for 10 Minutes
10. Shift Transmission to P (Park)
11. Allow engine to idle for 10 Minutes
12. Turn Off A/C Controls
13. Allow engine to idle for 10 Minutes
14. Turn Off engine for min 30 Seconds
15. Start the engine and Idle for one minute
Manual Transmission:
1. Ignition Off
5. Shift Transmission to Neutral
6. Start and Run engine at Idle
7. Turn ON A/C controls
8. Allow engine to idle for 10 Minutes
9. Turn Off A/C Controls
10. Allow engine to idle for 10 Minutes
11. Turn Off engine for min 30 Seconds
12. Start the engine and Idle for one minute.
Short Method from LS1 forum
Fast idle relearn [Archive] - Australian LS1 and Holden Forums
Short method after reset:
turn on the reds, don't start.
push the gas pedal down 3-5 times.
turn off reds
start car
My car is a stock standard 04 CV8 and I have tried the short method and it worked fine for me.
My car was idling high, around 1000/1100 rpm then after doing the relearn it has gone down to 800 (on the cluster not measuring with any plug in stuff).
Still goes a bit high when i first put the clutch in but, up say 50 to 150 rpm but aparently thats normal.
