vy lumina alarm questions???
Discussion in 'VY Holden Commodore (2002 - 2004)' started by SAV_117, Jul 31, 2008.
  1. SAV_117
    SAV_117 Donating Member
    VY Lumina
    just wondering if anyone knows if the lumina has an alarm and apparently there is a spec way to turn the alarms on or some**** apparently u press lock twice just wonderin if its true.
    thanks fellas
  2. Bravotwozero
    Bravotwozero New Member
    MY12 AMG C63 W204 Speedshift + 2013 KW T909
    Yes you press lock twice within 10 seconds. The indicators with then light up and stay on for a few seconds. The car is now deadlocked and the alarm is activated. Cool thing about it is that if the alarm is tripped, when you next turn the ignition on, it will display in the cluster where on the car the alarm was triggered. (Doors, boot, bonnet etc etc. )
    Does this on my SS but if you're not sure if the Lumina is the same, deadlock the car then pop the boot and it should go off.
  3. SAV_117
    VY Lumina
    alright cool thanks mate
  4. SAV_117
    VY Lumina
    just tried that it didnt work than i had a wonderful idea why not check the manual it said u can open the boot with out the alarm goin off maybe i should just shake the thing till i find out
  5. CANYONERO
    CANYONERO Likes Cheese...
    Country SA
    V8 6spd wif MOMO leavaa.
    pop your bonnet, close and lock your car then open the bonnet. scared the S*** outta me coz i found out by mistake!
  6. SAV_117
    VY Lumina
    hahah alright thanks mate
  7. SAV_117
    VY Lumina
    just tried it didnt go off i guess i dont have an alarm than i thought i would but yeah guss i dont
  8. CANYONERO
    Country SA
    mine took like a minute or two before it went off. i thought Vy came with them factory.
  9. SAV_117
    VY Lumina
    thats what i thought but yeah maybe i should leave it open a bit longer it deff deadlocks well i think it does cause i press lock the second time and the indicaters and **** stay on for a couple of secs and than go off maybe i should leave the bonnet open longer
  10. daron
    daron wizfiz
    adelaide
    VE SSV
    look for a bonnet pin under bonnet in the middle near the lever
    look for horn on pass side firewall
    if both present you have an alarm
    if not present you dont
  11. SAV_117
    VY Lumina
    thanks for that will do
  12. mmrdb
    mmrdb Member
    V2 series 3 Monaro & VF V8 Calais V Wagon
    Lock your car with the remote. Alarm should now be activated. Now open your door with the key without using the remote. Once your door is open the alarm should sound within a few seconds. Alarms were standard on the base models since the VX (not quite sure if series one or two). Anyway give it a go!
  13. SAV_117
    VY Lumina
    thanks for that will try it in the mornin
  14. SAV_117
    VY Lumina
    hey guys thanks for the help deff have an alarm lol put the key in and turned it when it was deadlocked **** that scared the **** out of me hahahhaa thanks to u mmrdb hahaha thanks for the help guys
  15. Cohan
    Cohan New Member
    Thornton
    VX Lumina
    Is this the same with the VX?
  16. DevilDRake
    DevilDRake Braaaap
    Skye
    2006 VZ SS 6L Ute
    Why don't you go try instead of bumping a 3 year old thread?
  17. VYHDT
    VYHDT Donating Member
    South-West Sydney
    VY HDT
