VY Mechanical Noise?
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Seth_23, Feb 10, 2011.
  1. Seth_23
    Seth_23 New Member
    Australia
    VY Series II V6 Sedan
    So this is going to be hard to explain, but when I drive my car at certain speeds, it makes a strange pulsating mechanical noise when I sit at certain speeds, usually 100Ks exactly, going slightly faster or slower, the sound goes away.
    Its very constant/rhythmic like "vrrr, vrrr, vrrr, vrrr". I'm not too sure if its coming from engine or g/box. Any help would be much appreciated!
  2. Sean880
    Sean880 Well-Known Member
    VIC / NSW
    2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
    Is the gear box manual or auto?
    Are you sure the noise originates from the engine or gearbox and not elsewhere up front? (Last time I heard a noise as you describe (not in a commodore) it was present most of the time when you applied the throttle and sounded like an auto gearbox problem, especially when under load. But the owner claimed it was something else).
    As you say the noise starts in your car at about 100 kms are you sure it is not front wheel/hub/bearing related? Just a thought.
