(VY) Oil in radiator. No coolant in oil.
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
As the title says. I'm using a small
amount of coolant, though none is
getting into the oil or trans. Small
amount of what looks like engine oil in
the coolant. Ecotec has NEVER
overheated, so what do you guys think?
Inlet manifold gasket?
edals
Inlet Manifold Gaskets Id say mate. As you have replaced the Radiator Twice i doubt you have another Dud !
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
The manifold kit costs about $80 bucks but you have to buy the two "O" rings for the pipes that go into the waterpump as they are not included . Bit of a pain in the butt when you have the motor apart and find out you have to buy them.
edals
oh oh and Injector o rings ! i had to go to 5 shops to find them !
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
Sounds like A bigger job than I've been
led to believe, water pump 'o' rings?
Injector seals? Doh!
ari666, would you not consider oil in the
radiator and dropping coolant level
broke?
Coolant level is now sitting at the
bottom of the raddy throat, whereas
before it would sit at the top, just
beneath the overflow hose. And I reckon
my cap is not the problem. Cheers.
DavesCalais
34
VT Calais
Not so much water pump o rings pretty sure there bypass pipes there easy enough to do
Sent from my XT910 using Tapatalk 2
edals
Yeah VYMAD, There are 2 O Rings for 2 of the Heater pipes that goes to the heater & 1 Pipe that goes through the Belt Tensioner you need to remove also part of the heater. Also you have to remove the Fuel rail so you will need new Injector O Rings as they are old & Cracked, you want a tight seal. Injector O Rings 5 Shops before someone had any, So be sure to get them before doing the job lol
Your Cap may be faulty if coolant is at the bottom of the neck of the radiator, My VX did this, replaced the cap, All good again, Has to do with it not allowing the flow between the radiator & Overflow.
