Dayvo
Because i can
- Apr 28, 2005
- 2,669
- 8,475
- 113
- Age
- 67
- Location
- South East,Victoria
- VE SV6 Series 2
It took me about 4 hours to do mine mainly because there was a ton of gasket glue holding it all together which makes me think it wasn't the first time it has been done . Also with the O rings I meant the heater pipes not the water pump . I don't recall taking of the fuel rail though . I took the manifold and fuel rail all in one .
Just remember to clean out the water pump holes where the pipes go so you don't stuff up the O rings and use heaps of vasoline when installing the , Other than that it is straight forward just time consuming . A quick tip is to spray shaving cream into the water passages on the heads to stop bits of gaskets falling in , then just vacuum it out when your finished .
