VY S I, fog lights plugged in but not working? wats next step? help !
angelkl27
ACT
VY S
hey guys
I recently put fog lights into my commodore, the wiring was there i plugged them in but they arent working, i dont know what the next step should be? do i have to get a switch or is it just a missing fuse ? are they suppose to turn on automatically with the parkers? :idea3:
would appreciate your help thnx
axemurderer101
Albany
forums.justcommodores.com.au
VY SS
chargedvx6
VY SII HBD Calais L67
Like said /\/\/\......a fog light enabled head light switch is needed. You will also need a relay to go in the blank hole in the relay box near the drivers side strut tower.
Braydenreid
canberra
S/C VX Calais
could you just set it up to your own seperate switch?
angelkl27
ACT
VY S
thnx guys for the help, didnt think they would be $77 !! -__- lol il probably check at wreckers see if they have them for cheaper
a1k3m1
Central Victoria
2003 VY II S-Pack 25th Anniversary
yeah ya could do that, or as others have said in making your own switch, its cheaper and better i think, as i did the same in my VY..
TMM
OEM+
VIC
VY Berlina S2
Why use a seperate switch? Looks ugly and the only limitation of the factory switch is that you must have the parkers on to turn the fogs on (which is the law!).
