Vy series 2 clubby- srs airbag light and instrument cluster replacement
Blackvzcalais
VY series 2 clubsport
Hi all,
I just bought a vy series 2 clubby and it has an srs airbag light. I am not sure what causes this but I have read that it can be if the instrument cluster has been changed.
Could anyone help with
1. How to remove the code, my autel scan tool won't pick up the airbag system.
2. Do hsv put any special marks to know if the cluster has been removed?
3. I think the car must have had a differentbecu put in it as when I run the vin check it comes up different to all the other plates on the car. Can I update the vin in the ecu?
Thanks in advance
Fu Manchu
WA.
It can all be updated. Its going to need a higher end diagnostic tool, preferably a Tech2.
The cluster will have an airbag mismatch. It thinks there are more airbags and can’t find them.
The VINs can be changed by an experienced Technician.
Blackvzcalais
Thanks mate for the info. Could the sirs light be also caused by removing the seats without disconnecting the battery?
Fu Manchu
WA.
It would be insanity to remove seats with airbags without deactivating the SRS system.
To find out more is going to require a high end diagnostic device. That will tell you exactly why the light is on.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
If anything in the SRS system is unplugged then the key turned on, it will set the light and will need turning off with a Tech2. The battery doesn't need to be disconnected to unplug the seats, but the key has to be off while they are unplugged.
TheIceman
VY Ex-cop
i always make a habit of taking fuse out no matter what when working with those yellow wires.
Blackvzcalais
Thanks everyone for the responses and looks like i need to take it to someone with a tech 2. Thanks again
Fu Manchu
WA.
A mobile mechanic might also be of assistance
vc commodore
Like the Leyland Brothers
VC, VH and VY
I have this light on as well....Mine is caused by resistance behind the steering wheel....ie, sounds like it is dirty behind the steering wheel, with the contacts...Haven't taken the steering wheel off yet to clean for it to be reset
TheIceman
VY Ex-cop
probably fuked clock spring.
  • Like
Reactions: Lex
