Vy Sports Binnacle
Discussion in 'VY Holden Commodore (2002 - 2004)' started by talgenn, Jan 6, 2004.
  1. talgenn
    talgenn Guest
    Has anybody installed the sports binnacle with the extra two guages after buying the car?
    I own a VY Clubby and i am interested in fitting the extra two guages.
    Do you know if all wireing looms in the dash have the required connections?
    Is it easy to install?
  2. fourstar82
    fourstar82 Head Chef Honcho
    Kilsyth, Melbourne
    VYII 25th Anniversary, 2007 VE Calais
    Try JHP They're in Melbourne but they do freight interstate i think.
    Andy
  3. vyss350
    vyss350 Guest
    QUOTE (talgenn @ Jan 6 2004, 12:56 PM) Has anybody installed the sports binnacle with the extra two guages after buying the car?
    talgenn,
    how did u go with the info on the binnacle guages?
    did u have any hastles? im thinkn of doin the same thing.
    whats it cost, etc?
  4. talgenn
    talgenn Guest
    I ended up going to my local holden dealer and found that they sell a kit with all the necessary parts to do the job. They supply wiring loom, guages and a handy set of instructions to guide your way through the installation process. There is a small wiring patch you need to install to be able to hook uo the new loom. You will also need to bolt on a VDO pressure sender on th engine. (just above the oil filter). The whole thing cost me about $650, a little pricey but well worth it, it totally changes the look of your dash.
    Good Luck........
  5. vyss350
    vyss350 Guest
    QUOTE (talgenn @ Feb 12 2004, 05:23 PM) I ended up going to my local holden dealer and found that they sell a kit with all the necessary parts to do the job. They supply wiring loom, guages and a handy set of instructions to guide your way through the installation process. There is a small wiring patch you need to install to be able to hook uo the new loom. You will also need to bolt on a VDO pressure sender on th engine. (just above the oil filter). The whole thing cost me about $650, a little pricey but well worth it, it totally changes the look of your dash.
    Good Luck........
    Thanks for the info, i will chase it up too.
    did you do all the instalations your self?
  6. talgenn
    talgenn Guest
    yes, it only took a couple of hours...
  7. Coupe 4
    Coupe 4 New Member
    HSV COUPE 4
    If you try JHP www.jhp.com.au they have the genuine HSV kit to suit all VYs, even with coloured dials
  8. VY2ENJOY
    VY2ENJOY New Member
    VY Family Truckster
    I installed some in my VY, used two autometer gauges, oil pressure, and trans temp cost half the price of the HSV one and IMO looks better
  9. OZ38
    OZ38 Member
    Jurien Bay WA
    VS V6 T5 & VY V6 M35 UTE
    the small wiring patch that you mention does it come with the kit and is it just a plug in set up thats easy to work out ?
  10. Torquative
    Torquative Sports Economy
    VE SV6 3.6L SIDI 6sp
    is it possible to find out how to remove the plastic bit off the dash without damaging either it or the dash?
    A little OT but I'm thinking of installing an SS "bin" in that area for remotes / cards etc but Ive been told theres bits and pieces under the plastic to watch out for, and that the bin wont suit, so I want to have a look before I waste money on the bin itself but dont want to damage either dash or plastic in case it cant be done!
  11. VY2ENJOY
    VY2ENJOY New Member
    VY Family Truckster
    I prized mine off with a small flat blade screw driver and it didnt make a mark.
  12. Torquative
    got it thanks!
    Had a look, I dont reckon it'll fit but ive got a SS bin coming in from Melbourne, hopefully before the weekend, so we'll see :)
  13. camvyss
    camvyss Doof, Doof, Doof
    Really Rural Queensland
    VY2 SS 5.7L A4
    I just got a quote back from JHP at $900. That's well over the genuine Holden at $650. So personally I'm going with the genuine.
