Not sure where to post this so hopefully I got it right, I did do a search for any similar issues. My VY SS central locking locks everytime I close the door. For example, the other night it was cold so I started it up to leave it running for 5 and upon returning the doors had locked. After playing around with it I came to realise that as soon as you close it while the doors are un-locked, they lock instantly. The driver's side door handle is a little difficult to action from both inside and outside the car. I've played with the settings but apart from 'auto lock in drive' there are no other features. I also reset factory settings but it still happens. Car is 100% stock, no mods. Anyone else had a similar issue? I'll take it back to the dealer next week but I am hoping there is an easy fix rather than going through all that. Cheers guys.
sounds like a r/h/f door actuator fault, u will get simmilar with a faulty actuator, and if ur drivers door is a little hard to action, was going to suggest the function settings, but if uv already tried this then might b ok there, is there a timer setting in the functions to lock it after xamount of seconds or minutes?
