VY SS cluster into a VY V6?
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Craig93, Feb 14, 2010.
  1. Craig93
    Craig93 New Member
    Central Coast
    VE SS SEDAN
    Looking to fit a VY SS dash to my VY V6 will it all fit sweet?
  2. Cobez
    Cobez LS-EXUAL
    2004 S2 VY SS Ute
    Nope. Will have to change a few looms etc i believe.
  3. Fekason
    Fekason Fekason
    Penrith NSW
    Maybe?
    In the VY, the clusters are programmed by Tech2, so a V8 cluster can be used in a V6 provided the cluster is programmed by Tech2 at Holden. There are other means of programming, but I can't give much more guidance on that.
    The major issue is that series 1 and 2 clusters are not fully compatiable. If the wrong series is installed, then the fuel guage will work backwards and DTE will be a useless function on the trip computer. Make sure that you get the compatiable cluster as the fix after installation is messy or expensive.
  4. PaulSV6
    PaulSV6 CHE Tuned 156.8rwkw
    Castle Hill
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Yes it will work, it just has to be reprogrammed by Holden using tech2. Make sure the SS cluster is the same series as your V6 otherwise the fuel gauge will work in reverse.
  5. Craig93
    Craig93 New Member
    Central Coast
    VE SS SEDAN
    sorry if its a dumb question but what is tech 2?
  6. PaulSV6
    Castle Hill
    Its a diagnostic tool, Holden uses to rectify, clear error msgs or run tests.
  7. frontier
    frontier New Member
    commodore VY 2004 SS
    is there alternate software we can install on Laptop and do diagnoses,programming like tech 2 through laptop ???
  8. PaulSV6
    Castle Hill
    Im not sure mate, but ive been thinking about it. As i have made up the necessary cable but just need the appropriate software.
    Im going to see Phreddy (ASR) on Monday night & ask him, so ill let ya know.
  9. jr689
    jr689 New Member
    NSW
    2003 VYII S 3.8L M5
    Hi just curious as to how you went with this I'm interested too. Cheers
  10. sp001in
    sp001in vyma100
    QLD
    VY ute
    here is mine. I have a Vy series 2 ute. I fitted the level 3 hsv cluster. Had to take it to Holden and get them to calibrate it to suit my car. eg. 6 cyl, fuel tank size, diff ratio, auto and the set the k's too.
    Dr.BOB who can still be found on here can do the work for you for $150, he can also supply the cluster. memcals.com.au is his site.
    check out my build to see it going in. http://forums.justcommodores.com.au/vy-vz-wk-wl-v2/96294-my-vy-ute-s2-hsv-mock-up.html
