VY SS Clutch Fail Problem
ONROADYNO
VZ Thunder
I have a standard VY SS Ute and just went to put into gear and as I did the clutch pedal went to the floor.
I pressure bled the slave cylinder and problem still there.
Any Ideas?
What is a good clutch/pressure plate to buy if I need a new one.
I drive normally till my inner bogan rears its head!
Thankyou in advance.
Dirbatua
AWOL!
S/e Victoria
VX SS Series 2
Any Ideas?
Master or slave cyl is probally rooted if the pedal has no pressure.
ONROADYNO
VZ Thunder
Dirbatua, thankyou for your input.
The pedal does have pressure but not enough to lift the pressure plate 100% off the clutch.
It really felt like there was a master cylinder bypass. I suppose if I change that and no improvement the gearbox comes out next.
ONROADYNO
VZ Thunder
Pretty sure its the slave cylinder but will be changing clutch and rear main at same time.
Any recommendations on what clutch to get.
The car is Granpa spec and I drive normal mostly with the occasional burnout.
Thankyou.
