VY SS to VZ SS conversion
Discussion in 'VY Holden Commodore (2002 - 2004)' started by FATMOE, Aug 31, 2011.
  1. FATMOE
    FATMOE New Member
    VY Clubsport R8
    Thinking of changing my VY SS front end to the VZ SS look, I'm thinking of going aftermarket which is the cheaper option but is it the better option like fitment wise, has anyone had problems with fitting aftermarket like gaps and tabs not lining up properly??
    What do you guys recommend I do, is it worth it?? I know I need to change bar, headlights, foggies and the fluted guards. You reckon I need a bonnet as well or can I get away with it?
  2. MEESEN
    MEESEN "SOON"
    '03 VY
    Think the bonnet is different from what I've read
  3. FATMOE
    FATMOE New Member
    VY Clubsport R8
    Yeah I heard that too, just want to know if the VY bonnet causes any issues clearance wise?
  4. MEESEN
    MEESEN "SOON"
    '03 VY
    Not too sure, think the grill is either wider or thinner and that's all
  5. FATMOE
    FATMOE New Member
    VY Clubsport R8
    Yeah I will get the VZ grille, just want to make sure the bonnet will be fine, I can use VY guards but what's the point of a VZ without flutes lol
  6. MEESEN
    MEESEN "SOON"
    '03 VY
    I mean the part of the bonnet that the grill sits under is either wider or shorter from memory so you'd need a new bonnet, but I'm not 100% sure, maybe just measure both a vy and someones Vz and see.
    And yes the flutes are a must :)
  7. FATMOE
    FATMOE New Member
    VY Clubsport R8
    I'll see how I go, I've never used aftermarket always genuine but atm a baby on the way, it's hard for genuine. Anyone had a bad experience with aftermarket parts???
  8. a1k3m1
    a1k3m1 New Member
    Central Victoria
    2003 VY II S-Pack 25th Anniversary
    yeah man the VY bonnet wont fit up with the VZ front, the VY has a more pointed front so youll have an ugly gap, the VY headlights are angled different to the VZ, The VY and VZ use the same side guards so you should be sweet with that the bumpers gonna need changing coz the obvious teardrop thing the VY's have,,
    I think non-genuine stuffs okay as long as it isnt chinese made, they always make cheap nasty stuff that breaks lol
  9. MEESEN
    MEESEN "SOON"
    '03 VY
    Yeah I usually use aftermarket and I've never had a problem :)
  10. one_and_only2004
    one_and_only2004 Turbo L98 FTW
    Regional NSW Australia
    Z Series Thunder Utility - Turbo
    You'll need
    Bonnet
    Bumper
    Headlights
    Grille
    You can get away with your standard VY guards I guess, but that's the main perk of the VZ. You're better off sourcing genuine second hand parts - non genuine front ends tend to fit pretty **** and droop to one side.
  11. rx2_freak
    rx2_freak Smokes, let's go.
    Churchill
    SSV Z SERIES SPORTWAGON
