Vy ss ute exhaust
Discussion in 'VY Holden Commodore (2002 - 2004)' started by utemanv8, Sep 21, 2010.
  1. utemanv8
    utemanv8 New Member
    VY 5.7 SS UTE
    Hello, i have a VY SS 02 Manual Ute with NO engine work, Ive had so many different things said to me about exhaust systems for these cars....i want to tell u wat Ive got and wat im looking for and if someone could please tell me the easiest way to achieve this...
    I have pacemaker extractors, hi flow cats and just had a full red-back 2.5 twin system cat back installed without a rear muffler/ resonator. I wasn't happy wit the sound as it droned and had a weird sound to it inside the car. So i got a rear resonator installed and now it doesnt resonate but its just to quite... every one tells me to put and 2.5 x-force system on but i just dont see it making that much difference....then ppl say to get a 3" system and i dont no where to go from here...Basically with the Pacemaker and Hi-Flow cats wat system should i run to get the v8 rumble and lumpy on idle without the resonating...cheers!!!
    PLZZZZZ help me!!!
  2. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    changing from one 2 1/2" to another won't change the power much mainly just the sound.
    A lot of people use the X force stainless as its a cheap system in stainless but a lot of them say the system sounds tinny and they drone.
    Twin 2 1/2" is big enough upto a mild cam, otr and mafless tune.
    Twin 3" only needed for big cams, low gears or forced inductions and without those type of mods you'll most likely get droning.
  3. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    I do a system that has hotdogs on the front and a resonator on the rear. It is nice and deep, louder than the system with front mufflers but doesn't drone.
  4. ssmate
    ssmate Member
    Melb
    ss thunder
    what system is that and how much?
  5. utemanv8
    utemanv8 New Member
    VY 5.7 SS UTE
    Ty for the reply, so do u no wat combo will give me wat I'm looking for? Wats the the 2 1/2 mild steel force system like do u think it would change the sound from the red back system? Thanks
  6. utemanv8
    utemanv8 New Member
    VY 5.7 SS UTE
    hey thanks for the reply, so u think if i remove the middle mufflers and replace it with hotdogs with my pacemaker extractors and high flow cats it will have a nice sound to it?
    would it have that lumpy sound on idle? i no its not going to be really lumpy but atm is so smooth it sounds like a 6. cheers.
  7. utemanv8
    utemanv8 New Member
    VY 5.7 SS UTE
    for the high flow cats and full 2 1/2" system it was bout $1200 the extractors were on it when i bought it...
  8. faBReGaS
    faBReGaS New Member
    251rwkw VY SS
    dude i have Pacemaker Tri-Y extractors, a full stainless steel 2.5" xForce exhaust with the centre mufflers and the rear ones along with 2 Sureflow ballistic cats on my VY SS and honestly i wouldnt go any louder than what i have. When im cruising you can hear the car but does not drone one bit.. when i put my foot down people have to block their ears on the street lol i highly recommend the set up i have.. it sounds awesome!
  9. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    It is a Manta system, I do them for $650 plus shipping. Comes with stainless tips too.
  10. utemanv8
    utemanv8 New Member
    VY 5.7 SS UTE
    so with the manta system wat do i actually get? mild steel 2 1/2" cat back system wit hot dogs in the middle and rear resonator?
  11. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Yep, exactly that. Bolts up to the flanges behind the cats, has glass packed perforated tube hotdogs in the front and a straight through twin in and out rear resonator with stainless rolled in tips that are angle cut. Mandrel bent too.
  12. utemanv8
    utemanv8 New Member
    VY 5.7 SS UTE
    hmm im in melbourne....so far...wat do u think full cost would be?
  13. monaro327
    monaro327 New Member
    VZ Skaife Senator & VY SS UTE
    why don't you try getting the front mufflers in your redback system replaced with hot dogs wont cost much.
  14. utemanv8
    utemanv8 New Member
    VY 5.7 SS UTE
    Yea that's wat I was thinking. Is there a brand I should go for? Do u think this will give me a nice note? Or should I just scrap it and start with a whole new system such as difflipio? Ty for all the help tho!
  15. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Exhaust note is very subjective. It all comes down to what you like.
    The cheapest solution would be to replace the front mufflers with perf tube glass packed hotdogs, don't use spiral louvre, as they will rust out in 6 months because they trap moisture.
