VY Stalls under Deceleration only
JasG
54
QLD
VY V6 Ute 03
Hi , I am new here great forum. I have a VY 03 V6 auto Ute, I am in need of help Please.
It runs great, Idles fine at lights never stalls otherwise, starts first turn. But once warmed up & only at speed(fine at lower speeds) Stalls as you decelerate say coming into a roundabout or down a hill. If i keep just a breath of throttle(drive double footed) to keep idle at say 1000rpm it fine, driving me nuts as if i let drop under that on decel it stalls & loose steering & brakes, put it in neutral hit key all good back in action. Its like the throttle body needed cleaning So did that, was a little dirty nothing major, pulled out Idle control solenoid cleaned as well. No difference, does have a slight vacuum sound especially when cold i don't recall being there before this started, i cannot find an air leak, no fault codes, no lights on, runs fine, idles everywhere else, but this is getting dangerous as if it stalls at wrong time as it doesn't always do it i could cause an accident. Its like i need to wind up idle just a bit, but i am aware you should not adjust the set screw. Been reading all the other comments with similar but worse issues & people advising changing coils, cam sensors, fuel pumps, ox sensors etc.. If it was any of that it would die all the time, it's more like you take your foot off throttle shuts and it starves for air & cuts out. I am thinking Idle control solenoid or Throttle position sensor or maybe air leak causing vacuum issue. Has anybody ever seen this? Really could do with some advice, Please. Thank you.
evBenji
VY Commodore
Cant give u a definite answer but once it heats up then it turns bad usually means crank angle sensor or dfi
But if like u say it just cuts out... or does it puff n spit n whinge and then stall
My initial thought would be to check fuel regulator if u go for a drive and after u can see the hose on the back of it is wet then its screwed
Else id lean to fuel pump relay or dirty fuel filter. Put injector cleaner through it or premium fuel. Swap pump relay with horn relay
Clean up battery terminals and get em on tight
Do u know how to test the coils?
Vaccum hoses u can get cheap from sprint auto park out the front and replace them all clamp them up tight. Theres about 4 all up to renew
At the back of driver side rocker theres a device where 2 vaccums hoses run to. Check if they're on tight and not split
Even check if oxygen sensors are in tight
All adds up
JasG
54
QLD
VY V6 Ute 03
evBenji Thank you, I appreciate any help here & advice. I'll check what you suggested see what happens. Not 100% on testing of coils though. Or crank & cam sensors. As for your first question, hard to say really as I see the tach start to waiver up & down & battery light flickers then it either kicks back into life or cuts dead, no puff n spit n whinge so I am able to feather throttle most times as all I need to do is breath on it keeping around 900-1000rpm fine. Most times I don't actually realise its stoped until I see the battery light on & steering goes heavy as its coasting. Would not the crank or cam sensor cause a larger issue than this? As I never plays up other than say above 60kms on decel, I read somewhere today possibly speed sensor but that would cause other issues as well if failure. Or EGR valve blockage, dam such a tough one. I feel vacuum as I said I hear it louder when cold as worms up goes away. I'll test what you said & reply when done with outcome. Thanks again, very grateful.
evBenji
VY Commodore
Can u start it straight away after it stalls
U have 3 coils. Test coil one at a time... turn car off. Take the 2 leads off 1 coil only. Start car. Watch the coil if the lightning bolts join neatly... the coil is ok.... if the lightning bolts frizz around go buzzurk its fkd..... turn car off... put 2 leads back on it... then try the next coil same way
I would try a new tb sensor... see if u can get 1 cheap off a gumtree wreck unless brand new is cheap
All weird if not getting errors on the dash? Could be ecu playing up (last resort)
JasG
54
QLD
VY V6 Ute 03
evBenji Thank you, legend mate, Yes starts straight away, no carrying on. When it happens I put into neutral hit key, back in action. Hard to do that all when your steering/turning, braking with a car up your clacker. Most times I can coast & do it, sometimes pull over. Hit key, on again. hard to turn a roundabout with no brakes & steering assist, nearly hit gutter a few times. Not good on P/Steering system, G/box etc as well as Autos don't like rolling at speed without converter turning. So this can cause many other issues the longer it continues.
My thoughts are throttle position sensor(computer going haywire when throttle returns to base) or idle control solenoid, or air leak as found rats have been living under manifold cover, they can do nasty things, see that before. Only seems to be one hose(oil breather) going into TB & a few small hoses(into cabin & FPR I think) & booster at rear of manifold, need to check more as fuel pressure vac line etc. Wondering if a manifold leak maybe.. as when I bought car invoice in glove box for manifold leak repair, but does not show any signs of ever being removed, as old oil & dirt says to me never been removed. I will see if I can find the procedure to test TPS etc, look more into air leak. Dam mystery that is weird & frustrating situation. Keep looking. Thanks for your help again. More heads are always better than one to bounce ideas off.
statey1975
WK Statesman
Not sure of the V6 setup, but on my old LS1 the joiners in my PCV hose were all perished causing vaccuum leaks, wreaked havoc on my engine when taking the foot off the accelerator. fixed them up and all good!
JasG
54
QLD
VY V6 Ute 03
statey1975 Hi Mate, Thank you, i have not had any time to look further so far, but yes good choice, i read somewhere similar issue can cause issues like this if vacuum leaking or especially if PCV is blocked up with gunk or in open position causes mixture issue confusing ECU. I only see a hose for breather coming off bottom of Throttle body S shaped going into manifold, it looks ok but by site only so far, i saw a diagram saying PCV valve lives between plenum & manifold dam i don't want to lift that area if i don't have to, hoses i hope/pray. I appreciate Any advice or direction. If anyone has diagrams or test procedures i'd be grateful also. Thanks again.
greenacc
Searching for the billion
VE Berlina
Does it idle ok and accelerate smoothly? It doesn't sound like TPS to me if the only trouble you have is cutting out when you back off.
JasG
54
QLD
VY V6 Ute 03
greenacc Thank you, Yes idles great, great smooth power, perfect otherwise than stalling on decel, its not doing it every time which is weird Never cold only once wormed up I believe when cold mixture is richer due to cold start etc, as worms up mixture leaner which brings me back to air leak. I can drive on freeway up down speed, stop start, but say come into roundabout or off ramp or at top of hill about to decline back off throttle at about 1000rpm tacho gives a little wave if it wavers down past say 500rpm out with the lights(well light come on as stalled), sometimes it will come back to life, I find if I just rest toe on throttle keeping at approx 900-1000rpm no issue. Driving me nuts trying to find issue. I have thought maybe throttle set screw may have a dent in centre ( Have seen this over years) from were it hits back to base, thought about tweak but they are set factory but over years it maybe worn a groove, as idle approx 800rpm in gear, maybe give it 1/4 of a 1/4 turn in see if it improves if I cant find a vacuum leak first, as if it was electrical it would cut out more regularly. Thanks for help.
speedyvn
Bannockburn, VIC
2003 VY Acclaim Wagon
Have you checked the operation of the brake booster? I know its odd and not the same car but a mates Subaru used to always do this, it ended up being the brake booster, doesn't take long to test its operation and whether its working or not.
greenacc
VE Berlina
Im getting confused. You said it idles fine but you say it stalls and you have to hold throttle open a bit. After you've been driving a while does it still idle fine or do you need to hold the throttle open?
Could it be a really dirty throttle body or air filter?
JasG
54
QLD
VY V6 Ute 03
speedyvn Thanks for your help. Possibility, does work fine but as you say could have a leak.
JasG
54
QLD
VY V6 Ute 03
greenacc Thanks for your reply & help. Always Idles fine, Only when decelerating at speed, say above 40-60kmh. Lower speeds ok, like pulling in driveway etc, at higher speeds say on freeway back off no problem, seems around that mid range area. if I breath on throttle doesn't do it. Its like the idle needs to come up approx 100rpm, Cleaned Throttle body & idle motor area. Was not to bad, usual black but was minor. Seen a hell of a lot worse over the years. Air & fuel filters about 10K ago. Due for oil & filter change now, leads & plugs could do with replacing soon. Driving me mad, no codes recorded, must be an air leak somewhere I'd say. I am thinking idles motor not working 100%. as throttle closes air to rich stalls. As it surges as its about to stall. tacho needle wavers up & down. Hmmm.
evBenji
VY Commodore
U posted this a month as ago and youre still pushing the same story that it might need this it might need that, have you even lifted the bonnet in this month
And ide air controller costs $20 bucks
New vaccum hoses costs $10
If its driving u so mad why not get it done tomorrow instead of pushing out hypothetical theories for another month
Lol dudes going ape
greenacc
VE Berlina
Do all your heater and AC controls work properly?
You can use some lube on the IAC seal if it's leaking air, I've been told Vaseline works...
JasG
54
QLD
VY V6 Ute 03
evBenji
You off Your Meds EvBenji?? Pull your Head in. I am not banging on at all, as two helpful guys with positive feedback(not like yourself) asked a question, I simply replied. Before you start Spewing your Negativity being a Keyboard Worrier without knowing someone's situation, I have not used this car as I have many cars & bikes, I have opened the bonnet & checked FYI, but as I don't use this car it is not priority, I'd just like to find the issue, as my colleges & employees have all come to no conclusion, And do not agree with your check coils, cam & crank sensor view as you must be the type that gives us all a bad name by Wasting customers money putting parts on that are not the answer hoping to stumble upon it then say BS to justify why the bill is so high. Check coils, check this, really? You Joker, Your a broken Tool. Everyone else has been respectful & helpful. Your the one going Ape, go to the hardware store & buy a bag of cement put it in your camomile tea & harden up.
JasG
54
QLD
VY V6 Ute 03
greenacc Thank you for your Positive reply, Yes they do, that was my first thought a leak back into cabin control area as I have seen that before. I disconnected & blocked the vacuum line to check. Yes vaseline or red rubber grease work well. Thank you very much for your respectful input.
evBenji
VY Commodore
So youve done nothing to address the issue except post lovely theories and draw everyones attention who are people trying to help you and your doing nothing with their educated responses except waiting for the next educated response in which u wont listen to again or take action in towards solving the issue and really your wasting everyones time.
Also do u think your 2 page outburst back there made me look bad or made yourself look even more menstrual than you already seem?
JasG
54
QLD
VY V6 Ute 03
evBenji So here you go again, Dribbling away, trying to justifying your existence. Yes you do look pathetically bad, If you Read, which you seem to be struggling with. I Never asked Another question, answers were given to Original post by Educated people which you seem to not be. I simply replied to them, out of respect for there valued input, which yours is not. You are wasting your time wanting what? A cuddle?Respect? A pat on the head. You lost that one, trying to gain attention for your self importance, self absorbed rant. Go play with your Lego blocks little man, your obviously not a qualified mechanic with experience. Yo Muma will bring you some milk. Your "Assuming" again, making an Ass of yourself not me. I valued & listened to there helpful educated responses, yours I do not. It is not any of the kind responses given as FYI I have checked & done. As I have highly skilled & qualified technicians that do know what they are talking about still have never seen this. So go change your pad & stop bleeding all over what you seem to think is your bedroom.
evBenji
VY Commodore
If u have a look dude i am not falling to your level and playing online male bonding keyboard wars and insulting you to the best of my ability and im also sure youre breaking forum rules in your immature bundle of insults but you continue youre making yourself look truly super
What i will say though is the best fix for your car would be to give it a new owner because with you and your array of expert staff looking after it, it obviously has no hope of being fixed.
And im a keyboard worrior am i? I worry about keyboards do i?
