twentyfouroz
- Jan 8, 2021
- 7
- 6
- 3
- Age
- 54
- Location
- Adelaide
- VY and VX wagon
Hola. Log time lurker, first-time poster, multi-dunnydore owner. The issue I have today is with my 3.8L VY wagon. I found a low km Ecotech last year, and on Jan 2 2021 I swapped out my leaky 290k+ chugger. The job itself was a %^$#ing nightmare ( stripped and snapping studs and bolts, random parts missing, etc. ) but by C.O.B Monday I had the old-new motor on the mounts and mostly connected back up. I drove the car in on the Friday before... so at that stage, EVERYTHING worked fine. Fast forward to Tuesday and there's no way it will run. It kicks and fires, sometimes I can rev it almost to 1500 RPM and it sounds fine... then it shuts off. First thing I thought was air leaks, so I eradicated that as an option. Then, because it backfired sometimes I thought maybe I had crossed plug leads. But they were fine / correct. Then I thought maybe coil pack, so I swapped that... no difference. Next I wondered if it was the immobilizer, but I got a new battery for the remote and did the reset trick ( disconnect battery, turn on headlights ). No change, and the padlock on the dash goes "out" when I turn the key. In between, the starter failed... so I got another one. I also replaced the plugs. All my "mates" said it was the CAS for sure, so today I replaced that. 4 hours later it was all back in. No change.
Now I am kinda nowhere, because I think I've gone through all the logical things that could be causing the issue. I could easily throw away $1500 replacing parts ( fuel pump, both CATs, ECU, BCM, various sensor) and still not get it running because I never got to the bottom of it.
Is this some weird ECU thing where the map is off? Or it's forgotten the engine timing? As far as I can see all the peripheral stuff is fine. I'm through the looking glass now. Anyone had this happen? What did you do? What fixed it?
