VY Steering Wheel Buttons
Discussion in 'VY Holden Commodore (2002 - 2004)' started by teagan_150, Nov 7, 2008.
  1. teagan_150
    teagan_150 New Member
    2003 Commodore VY S2 Executive
    A have recently bought a 2003 VY series 2 executive and i am having problems with the buttons on the steering wheel. Volume up mutes and volume down actually turns the volume up. Any ideas on how this is fixed?
  2. MEANVY
    MEANVY Donating Member
    Darwin, NT
    VY Omega
    sounds like a couple of mixed up wires, if mute turns it down...
    take the wheel out and unscrew the back, you should be able to see where the wires are coming to and going from. if your not up to it you might take it to a cheapy place, like autobarn or something, or you could bring it up at your next service?
  3. Bravotwozero
    Bravotwozero New Member
    MY12 AMG C63 W204 Speedshift + 2013 KW T909
    No it has nothing to do with wiring. Mine does it as well occasionally. I believe it is a BCM issue. Pretty common fault.
  4. Farlig
    Farlig Member
    Y-Series Clubsport
    its well documented in the VY faults thread guys.
    i had this issue with my old vy acclaim, 1/10 times it was dickie, i just lightly taped the side of them and it fixed it :S on the clubby i have never had this issue *touch wood*
  5. VYClubby
    VYClubby Proud Clubby Owner
    294rwkw Oztrack Tuned 220 cam
  6. cewing
    cewing Member
    Castle Hill
    VE SSV SWAGON
    mines USED to do that. I've had it fixed. THey use a voltage divider system, and theres a shorting somewhere, causing incorrect signals to be sent. When phreddy did my lights and stereo, he kindly just resoldered the connections on the remote.
    Its not a hard thing to do yourself, i find it fairly easy if your careful(but im an electrician)
    IN the >3 months since its been fixed, its only gone spazo 1 or 2 times
  7. teagan_150
    the problem is only happening some times about 80% of the time, the rest of the time it works fine. i pulled apart the steering wheel on the weekend and the circuit board all looked fine, solders were in good condition and there were no other problems with it.
