The antenna should work automatically if its genuine one, as that is what happened with the one I changed over,
Does the antenna work ?,
Best to remove the antenna and check to se if your getting the trigger voltage at the antenna connector,
You will need 2 people to do this, one to check for voltage, the other person to press the up down button.
If you do get 12 volts on either pin of the connector,
possibility its the antenna, if so, source a replacement Antenna, either the car grave yard, or a wrecker, approx. $25 > $30
I have replaced a few antenna's over the years on my VY, and a friends VT's, VX's and VY's,
The VT > VY antenna's are exactly the same, where the VZ's are a little different, as they have a plastic motor housing and a quieter when operating up and down, but will fit VT > VY models.
Very simple to do, just have to make sure the replacement does actually work CORRECTLY before installing it,
because it can be frustrating if you install it, put it all back together and it doesn't work.
The best way to test it, is to make sure you have 12v Negative (-) connected to the body of the antenna, where the Black Wire is connected to the mounting bracket,
and the to 2 other wires are the control/trigger wires, they are Red & White,
I am unsure to which is the up and down wire,
connect the Positive (+) side of a battery to either wire, and it should operate, and if it work ok, install it.
But make sure the bolt the secures it to the body in the guard is tight, and you get the rubber grommet in correctly,
otherwise water can get inside, and run down into the BCM
good luck.
