vy stopped running
mtp13
gulgong
vy commodore ute
Hi all
Just wondering if any one would know why my vy ute would stop running mid drive and then not start? It turns over but wont actually start and today i went and see if i could find the prob myself and noticed the battery was srewed , so i replaced it with a new 1 and still it wont start any ideas would be much appreciated
Sean880
VIC / NSW
2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
Did you have a "check engine" warning displayed on your dash or any other warnings displaying previously or now?
mtp13
gulgong
vy commodore ute
there were no warning displays now or in the past,as for the engine it turns over but thats all it does there are no strange noises or anything like that when i try and start it ,its just a great mystery
Sean880
VIC / NSW
Possibly the FUEL PUMP has failed. I would first check:
1. the fuse(15 amp) for the Fuel Pump; and
2. the Fuel Pump relay
Both are located in the engine compartment fuse/relay box on the driver's side.
Damo69
VY Commodore S1 A4 Executive & VY ute A4
It maybe a loose connection (pin connector) on your DFI module, try taking it out then putting it back in again. If your ute still does start it could either be your DFI module is rooted. The other option is the Crank Angle Sensor is gone?
Good luck with it...
Damo
mtp13
gulgong
vy commodore ute
fuel pump is working fine but there is no spark
colgf
s/charged v6 HR Holden, s/charged v6 EH Holden,
Try Crank Angle Sensor too , although normally it would trigger a fault code & put the engine warning light on , but has been known to not!!!
