VY SV8 Issues
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Cyb3r, Aug 19, 2008.
  1. Cyb3r
    Cyb3r New Member
    VT Acclaim S1
    Hi,
    Purchased a VY SV8 last week and so far the experience of the 8 has been awesome :)
    However there are a few problems with the car that I'm hoping will be covered under warranty, as such some help ID the problems would be awesome.
    1. Engine makes a crunch/grinding noise for about half a second (towards the drivers side), once, just after the ignition is on put in drive and the car is moving about 2 seconds after the car starts to move.
    2. Brake pedal makes a crackling/creaking noise when depressing it
    3. Steering wheel shudders at 90KM/H-100KM/H
    4. Steering wheel makes a whiny noise when turning at low speeds
    Any thoughts would be fantastic so as I can arm the dealer with my problems!
  2. klaw81
    klaw81 New Member
    Toowoomba
    VYII SV8
    The wheel shudder at a particular speed is probably just a wheel that's out of balance or alignment - this is very simple to fix.
    The whiny noise during low speed turning is almost certainly coming from the power steering pump, which might be running low on fluid, or perhaps becoming worn out. Check the fluid level first, and if that's not the problem, ask a mechanic to check it out.
  3. batemada
    batemada Member
    Wellington, New Zealand (Yes i know yet another KI
    2009 Gold Calais V Sportwagon
    For fault #1 i have the same problem on my VY S2, it is actually your drivers side front brake rubbing and according to holden is normal.
    They told me that it is just my ABS system making sure the pads are all aligned up correctly.
  4. adamc11
    adamc11 Donating Member
    Melbourne Inner East
    2013 VE SS V Z M6
    1. Have you let it go in to drive properly before you start moving?
    2. No idea.
    3. As stated possibly an alignment issue, but could also be a buckled rim.
    4. As mentioned, check your fluid levels. But i'm pretty sure it was normal for the holdens to make a whiny noise (which was later fixed under warranty by putting in a bigger hose or something? - i could be wrong). My VY has a bit of a whine sometimes when turning.
  5. Cyb3r
    Cyb3r New Member
    VT Acclaim S1
    Hi,
    first of thanks!
    Second, yup I've check the power steering fluid levels and its fine.
    i figured the shudder would be allingment/balance. The wheels/tyres and only 3000KM's old and I took them of my old VT.
    I've booked it in for tomorrow for them to have a look.
  6. Joey_21
    Joey_21 New Member
    Western Suburbs
    VY SV8 HBD---mmmm LS1
    ahhhh dont tell me all these problems i just bought an sv8 pick up friday hope mines ok seemed alright in thne test drive lol
  7. Joey_21
    Joey_21 New Member
    Western Suburbs
  8. Cyb3r
    Cyb3r New Member
    VT Acclaim S1
    Not at the moment hehe... I'll have to grab some soon.
    There nothing major, the car still runs like a dream.
  9. CANYONERO
    CANYONERO Likes Cheese...
    Country SA
    V8 6spd wif MOMO leavaa.
    my SV8 runs perfectly.... excellent bang for your buck.
  10. Flat_White
    Flat_White Banned
    Rolls Royce "Fantom"
    Woah!
    I have problem number one aswell....
    Ive got no idea what it is either........
  11. Farlig
    Farlig Member
    Y-Series Clubsport
    every VY i have owned does it. its simply the abs system initiating on first movement. its all normal. its not a time delay its a set speed delay after moving, something like 5km/hr
  12. davey g-force
    davey g-force I'm a sceptic...
    "...the winner is..."
    02 RX7 S8 Spirit R 13B TT & 2013 Audi A3 1.8T DSG7
    The wheel shudder at speed is a wheel BALANCE, not a wheel alignment.
    No, you're thinking of a different problem. It was the power steering SHUDDER (at full lock) which was fixed under warranty by installing a bigger hose.
    Correct, though I'm pretty sure it's neither time OR speed dependent. I think you'll find it just happens the first time you press the accelerator. :thumbsup:
