VY UTE MYSTERY
Michael W
Therat
2012 VE SV6
Hi fellas see if you can help me with this please
Have a VY V6 have had starting problems
Things replaced
New fuel pump and filter
New injectors
New CAS
New leads and plugs
New senors alternator belt
Put the injector pulse light on them and injectors dont have a pulse
The ute when left over night will start with no problem and drive around from 1 day to 3 days then you stop and wont start again but leave it for 24 Hrs and it will fire up again
Any one have any ideas
immortality
Staff member
Sth Auck, NZ
Can you borrow a DFI module from someone to test with? The PCM gets the timing signal from the CAS but it goes through the DFI module to the PCM.
Michael W
Therat
2012 VE SV6
Have run it over the computer and dosnt bring up any faults even tryed a friends slip ring in case it was a key problem
immortality
Staff member
Sth Auck, NZ
Or wiring loom issue. An old work mate had a similar issue on his VY and it turned out to be oil contamination in the CAS plug.
Michael W
Therat
2012 VE SV6
That all seems fine as well only thing can put it down to is electrical
