VY v6 auto ute tailshaft swap to vz?
turbovich
perth
vy
Can anyone confirm if entire tailshaft unit and centre bearing are interchangeable ? Im thinking centre bearing maybe, but concerned about length.
_R_J_K_
Zenki S14
To what kind of body?
Typically in the past for Commodores if the tailshaft splits the front half is engine/gearbox specific and the rear half is body type specific. Can't really confirm for VT onwards tho as I haven't dealt with them.
turbovich
perth
vy
Yeah ok, i didnt know that. Thanks.
Body is utility.
EYY
VS Statesman
You can't always mix and match either. The two halves have matched splines. Sometimes you can get lucky and the splines are machined close enough to one another that you can mix and match. I've tried it before - it's luck of the draw.
If they both have the 4l60e I'd be very surprised if they're not interchangeable.
losh1971
North Tas
VE Series I SS Ute
yeah but what year did they change the diff end at the diff?
turbovich
perth
vy
Thanks for the replies anyway guys.
I'll shelve this one in the 'too hard ...' and fit new centre bearing.
Ian Dixon
53
Dubbo
Holden Commodore Ute vy 2003
Will a VZ sedan tail Shaft fit a vy Ute
Jolls
Donating Member
Murrumbateman
VY SS Ute (Jimi Hendrix)
Hi Ian
I think that they do as long as it is auto for auto and manual for manual. The V6 and V8 setups are also a point of differentiation and they changed the V6 setup for 03 onwards. So in short they should but there are a few variables that you need to take into consideration. I recommend you grab your phone and a tape measure and measure up/compare what is there now with the potential replacement,
Cheers n Beers
Jolls
Ian Dixon
53
Dubbo
Will a VY 2002tallshaft fit a2003vy Holden Ute
