VY V6 Cruise Control ... Series 1 vs Series 2 different somehow?
Discussion in 'Electrical Wiring / Questions' started by McAwesome, Mar 30, 2013.
  1. McAwesome
    McAwesome New Member
    VY Wagon
    Hey Guys, I have just bought a VY V6 Series 1 Wagon (Granny Spec) to get me around while in between 4x4's.
    The wagon of doom does not have cruise control, so I have been researching for the past two days to find out what is involved. (It will be doing a lot of long distance cruising).
    So far I believe that I need;
    # Cruise Control Module.
    # Cruise Control Throttle Cable.
    # Throttle Body Cable Linkage to support both Throttle Cables.
    # Brake Switch.
    # Cruise Stalk.
    And also the loom needs to be in the car (Which I am not sure if it has, as I have not picked it up yet and didn't look for the needed plugs while inspecting).
    Then I came across this, VY SER II CRUISE CONTROL KIT
    Holmart says (And I presume that they know what they are talking about), that it suits series 2 only.
    Can anyone tell me why this would not suit a series 1?
    What is the difference between the series one and series 2 cruise control?
    Can a series 2 system be made to work with a series 1?
    edit: I also have been unable to find what is involved in regards to wiring cruise control into a VY that doesn't have a loom/plugs already there ... any ideas?
    Many thanks to anyone that can shed some light on this subject.
  2. Tasmaniak
    S.E. Melbourne
    Vyii saw the introduction of a whole new ecu type. Oem cruise controls interface with ecu for its commands. You might be better of using a universal.
    But please f you get any information that is different I would love to know for my own knowledge.
  3. aaronevolution
    aaronevolution Donating Member
    Hastings, Victoria
    TURISMO VZ SS 6.0
    I used to have a 03 VY, now I have an 06 VZ. The only difference i found is the direction in which you turn the stalk to set and reset cruise control has been flipped.
  4. Fr4u4ka
    Fr4u4ka New Member
    Vy1TonUte
    Went to this guy Straya day weekend, everything works sweet and he is a top bloke. Happy to answer any questions.
  5. McAwesome
    VY Wagon
    Cheers for all the help guys, It is much appreciated.
    I pick the car up in two days, I'll have a better look at it to see exactly what I am dealing with and then get back to you.
  6. Tasmaniak
    S.E. Melbourne
    interesting that he doesn't do VZ... I'm wondering if thats the same as the VYII?
  7. McAwesome
    VY Wagon
    Well I picked up the car last night and unfortunately there is no loom for cruise control.
    So I have been offered a "Command AP50" unit from a wanted ad on gumtree.
    The reviews on them seem to be pretty good, so I think that I will give it a shot.
    Has anyone put one on a VY V6 before?
    I am asking because it seems that you can either wire them up with magnets on the driveshaft or you can hook them up to some sort of pulsing wire (eg electronic speedo), and I am wondering the best way to do so.
    Thanks for all help so far.
  8. Tasmaniak
    S.E. Melbourne
    if I had a buck for everyone of those I have installed....But you know, I don't recall ever fitting one into a VY before! lol What I can tell you is that using the VSS (pulsing wire) is by far the best way and most reliable to go. The catch is finding it.... When I need to find this wire, I first look at the Cruise Control lol. Bugger.
    Will have a look through my books and see if I have done one and if so where I tagged it. (I keep a log on most cars the first time I work on them.)
  9. Tasmaniak
    S.E. Melbourne
    First off, here is what I have from a VT. What I have written (scribbled) C6 and D5 - Purple w/White ECM Passenger Kick panel. Unfortunately it's a bitch of a thing to test. You need two people (one to test and the other to drive) or the back wheels off the ground. Test the wires with a multimeter (That does not says Test Light....) on AC Voltage you should see the voltage rise as the speed of the wheels increases.
    -EDIT-Oh I also have written 10K which indicates the AP50 should be set to 10,000ppm (pulses per mile) and also just thinking about it, that purple wire sohuld also be found at the dash cluster.
  10. Tasmaniak
    S.E. Melbourne
    Sweet I found it! (I'm seriously going to get banned for spamming here hahaha) Yes, I did a VY years and years ago! I have written behind glove box, GPS Connector, Purple w/White and ignition also available (I haven't written what colour.)
    Knew all these chicken scratchings would come in handy one day lol
  11. McAwesome
    VY Wagon
    Muchas gracias amigo!
    I should be able to pick up the AP50 unit and try to install it this weekend.
    How do you rate the unit?, Did any come back to you due to faults/failures?
    Another quickie...If I don't ask now I will never know.
    In my manual, it states that when cruise control is engaged (factory cruise), it goes into some mode that is distinctly different from the "power" or "normal" modes that you can select on the transmission tunnel.
    Would this be the "lean cruise" style mode?
    What else would the factory cruise control do to the engine/transmission computers when activated?
    Does "lean cruise" only get activated when the factory cruise control is used?, or will it be activated with the "ap50" unit simulating a steady throttle?
    I guess what I'm asking is, will "lean cruise" be activated by an aftermarket cruise control system?
    Cheers Tasmaniak ... Is there rep on this site?
  12. Tasmaniak
    S.E. Melbourne
    I rate the unit very highly in reliability. It's not feature packed but who cares. On/Off/Set/Coast/Accelerate. What more? The VY doesn't need Drive By Wire and it doesn't need preset speeds.
    This is the first I have heard of the cruise activating a Lean Burn/cruise setting on the car. Will have to look into that. With that being said, I can tell you that the AP50 will not activate. The car will not see a "steady throttle"...infact, thats the last thing that cruise control does. Infact, Cruise continously adjusts your throttle. so little rises and dips that you probably can't see, the cruise will react to. When it's installed, drive along a road and just rest your foot on the throttle, you will feel on a regular basis that the pedal will actually push aginst your foot from time to time as the cruise lets go whiule you go down hill.
    I'm gonna have a look and see if I can't find a way to kick in this lean burn mode.
    The forum used to have rep, but I don't think it does anymore... mind you, I still have my rep points (little green squares beside my name) I think the only thing left now is to "Like" a post. But thats not neccessary... I have the warm fuzzy feeling inside from helping someone out. lol
    Lol, just found out its still there. In the bottom left of each post is a little tiny "Sheriffs" star. That adds rep. But as I said mate... I don't need it.
  13. McAwesome
    VY Wagon
    Cheers Tas.
    Here is an excerpt from an "Autospeed" article discussing the Lean cruise" function.
    "Under cruise conditions, the VN-VPs cruise on 14.7:1, while VRs onward use a lean cruise function. Lean cruise kicks in once coolant temperature is over 80 degrees C, you're travelling faster than 68 km/h, the engine is spinning at between 1600 and 2800 rpm and manifold vacuum is between 40 kPa and 60 kPa absolute (the VS-on works on an airflow meter signal). Once 150 seconds is timed out under those conditions, the air-fuel ratio will lean out one point every 0.15 seconds. They're set up to run as lean as 16.5:1 - but only at that light load cruise situation. You can't be driving on and off the throttle.
    When we map an early V6, we'll usually put VR lean cruise into the program. We can also change the parameters - like the 150-second delay - inside the software. This all makes your fuel economy skyrocket."
    By "steady throttle" I meant steady speed ... but anyway, it looks like the conditions needed for "lean cruise" to initiate do not have anything to do with the factory cruise control.
    As long as an aftermarket cruise control systems can keep the engine within the criteria above ... then it should activate!?
    Fingers crossed haha
    I don't know why I care so much about this, I have just sold a Toyota FJ40 that averaged 23l per 100k that I have been daily driving for years .. I guess I just like to do things right the first time!
    PS, It seems that I can only "sherrif's star" my own posts ... lol
    Al I can do for you is report your posts! haha
  14. markbaja
    markbaja New Member
    VY Exec & SZ Territory Diesel
    Actually it says it in the manual, all cruise control does is use it's "own" transmission calibration, as in not really power, not really normal, but somewhere in the middle.
    On the vy, if you press power button, then activate cruise, power mode turns off, then turns back on when you cancel cruise.
    So I guess that's the only thing you'll miss out on, if you want power mode on or off while cruise is activated, it'll be your choice.
    Hope that's some help.
    Sent from my GT-I9100 using Tapatalk 2
  15. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    rep is the star at the bottom of each post. next to the triangle with the exclamation mark
  16. McAwesome
    VY Wagon
    I just picked up the AP50 unit and am reading the install instructions now.
    I am specifically reading the section on "Magnet and Speed Sensor Installation".
    Here is a quote.
    "The speed sensor, along with a magnet provide distance pulses to the cruise control. When the drive shaft rotates, the magnet attached to it moves past the speed coil. This generates electrical pulses which are counted by the cruise control.
    This cruise control has been optimised to work with the speed coil and magnet pickup or a Universal Speed Pulse Generator, it will not function of existing speed signals used for ECM or speedo.
    Do not connect to signals other than the Speed Coil or Universal Speed Pulse Generator as this may damage the input."
    Reading this makes me freak out a little.
    Their is two wires going to the speed pickup coil, How exactly did you hook them up to the VSS?
    Could giving them a powered source like the VSS destroy the unit?
    Lucky last, what does a GPS connector plug look like, got a pic?
    I owe you guys a beer.
    McAwesome.
  17. McAwesome
    VY Wagon
    The star only appears on my posts?
    aussie4life11 likes this.
  18. aussie4life11
    Western Australia
    Maybe its cos your new. i can see a star on every post on the forum but i have been around for a while. I will demonstrate.
  19. McAwesome
    VY Wagon
    OK, so I am looking for the VSS. (assuming it is ok to use, if you read my post above).
    Which one is the GPS plug? (Gear Position Sensor I am assuming?), is it the one on the left where my finger is holding up the two purple with white wires?
  20. Tasmaniak
    S.E. Melbourne
    Yes mate, those are the wires but not the GPS plug... you could use them. The GPS plug is a white connector designed for plugging in OEM SatNav.
    Unfortunately, those wires are what you would use for a Cruise Control but useless for yours. Mate, I have to give you a whole hearted apology. I misunderstood your post (several of them actually) and I thought you were talking about Command AP150. Which allows you to use those wires and no magnets. The AP50 does need magnets unfortunately. I'm really sorry about the duff information. Hopefully you can easily resolve it.
    With that being said, the magnets around the tailshaft does work just fine, but I definetly prefer not to use it.
    Again, I'm sorry mate!.... arne't you lucky you did give me rep yet? hehe
