VY_SP4C
Hi
I have a 2004 vy spac ecotec 3.8 i have come across a rough idle while in drive parked at lights or stopped in traffic it is slightly there in neutral/park if i bring the revs up to about 1000rpm it dissapears. it has progressivly got worse when plugged in to a computer by a mechanic he came up with nothing, i have so far changed coilpacks, leads, plugs, engine mounts and the gearbox mount i have the twin cat setup someone told me this could be the problem? Also i noticed while the car was running if i unplug the air temp sensor the maf sensor or the IAC sensor nothing seems to change it still idles exactly the same.
any help would be appreciated Thanks
