Vy v6 starts not running
Dirtyv6
Donating Member
VS Ute 3.8 V6
Hi all,
Vy v6 ecotec.
Drive home was fine, no problems.
Parked, came back 15min later would not start, would not even crank.
Swapped out coil packs, plugs, no change. Checked for fuel, fuel there.
Replaced crank angle and cam angle sensors, it now cranks and starts, but immediately dies. Will run if you keep a foot on the accelerator, but will go from barely idling at 800 rpm to 4500rpm with no pedal movement.
Sounds best I can describe like a enormous cam, really really choppy.
I I thought maybe a vacuum leak but I've checked and everything seems okay.
I can hear what I think is hissing but it sounds like it's coming up through the shifter.?
Not throwing codes.
Genuinely unsure as to what's next.
I'm thinking maybe inlet manifold gaskets or head but just unsure.
TheIceman
VY Ex-cop
hard without seeing it or listening it, upload a youtube video.
sort of sounds like fuel pressure issue. put a pressure gauge on it.
Dirtyv6
Donating Member
VS Ute 3.8 V6
Good idea actually.
How much movement should the injectors have? I was able to spin them around by hand.
TheIceman
VY Ex-cop
check fuel pressure, can turn injectors, thats normal. they are just on 2 'O' rings
Dirtyv6
Donating Member
VS Ute 3.8 V6
Pulled the plenum off to check the fuel pressure regulator, and found the gasket ripped on the front runner. Would this be the cause of my issue?
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
If it's not cranking at all it could be a security issue with key, starter relay, BCM or starter motor. The BCM wont let the relay engage for the starter motor until the correct key fob is present.
Now that it's cranking it sounds like either to lean or to rich, the only things left that would make it that bad would be DFI module or injectors/fuel pump. I wouldn't worry to much about gaskets a small leak will just sque the fuel ratios which the o2 sensor and MAF will auto correct it should still run better than that with a gasket leak.
Dirtyv6
Donating Member
VS Ute 3.8 V6
You're right, replaced the gaskets and still no change.
I've swapped a few DFI modules in and haven't had any changes.
Next step as suggested above will be checking fuel pressure.
Can I ask, how far in should the injectors sit?
just want to make sure its not something as simple as I haven't got them in far enough.
The1
QLD
www.eyeit.org
VS V6 Berlina Auto
injectors look fine, below the green bit is a black rubber oring.
Check fuel pressure otherwise get injectors tested and cleaned.
evBenji
VY Commodore
could it be the MAF sensor? i think i left a plug off the maf once and it went a bit bazzurk
before your video was thinking TPS, are all the vaccum hoses on and sealed, especially at the back of the rocker cover driver side theres a little device with 2 vaccum hoses, fl
u could have a snapped little wire on a sensor and very hard to find
clear the service error
are there any check engine warnings coming up, gotta be a sensor plug hanging off somewhere i reckon
