vy2 sedan SRS alarm
Discussion in 'VY Holden Commodore (2002 - 2004)' started by vy2, Aug 20, 2012.
  1. vy2
    vy2 New Member
    VYII Executive V6
    It had the problem for 6 months. The alarm was cleared twice but the alarm came back again in 1 week or so. Mechanic couldn't tell the problem. The electrician can't have any clue either, he suspects it could be the SRS chip issue, it's a old car, 2003 vy2. but it might cost couple hundreds if replacing that chip. He said it doesn't worth the money any way.
    Did anyone see or have the same problem, and any idea? Thanks!
  2. som
    som New Member
    thorneside qld
    vt executive
    There are a couple of possibilities.I've seen on this forum where,from memory, members have replaced the clock spring to fix it.In my case I replaced the BCM(or should I say had the BCM replaced) and that immediately fixed it but my car had developed other issues re aircon and high speed fan which pointed in that direction.I'd suggest that you could look for previous threads re clock spring replacement to see if that may help you.Good Luck.
