vyss manual will not shift into any gear
Discussion in 'VY Holden Commodore (2002 - 2004)' started by cubic inches, Jul 18, 2009.
  1. cubic inches
    cubic inches New Member
    vxss vnss
    vyss will not shift into any gear. does the hydraulic clutch have to be bleed or could it be something else.any info would be appreciated
  2. HARVZ-6
    HARVZ-6 New Member
    Riverton sa
    VT spac super6
    can you get gears with the engine off
  3. alien
    alien New Member
    Tullamarine, Vic
    03 VY Supercharged 3.8L
    You shouldn't have to bleed the system. All it is is the reservoir connected to the main cylinder which then pressurises the line for the slave cylinder. I would bet my money on something else.
  4. Fekason
    Fekason Fekason
    Penrith NSW
    Preesure Plate?
    From my experience, the collapse of the pressure plate will give this symptom.
  5. cubic inches
    vxss vnss
    yes,it shifts into gears with the engine not running.
