Sergeo
- Jan 8, 2008
- 9
- 0
- 1
- VZ calais v6 3.6
hi lads
I've got a problem with a current leak in my VZ 05 calais. i've narrowed the problem down to the electric seats or possible the Memory seat module/ switch.
I've had the battery run flat 3 times all overnight, and the problem has gone away ever since i disconnected the fuse for the electric seats ( no more leak, but both passenger and driver seats AND mirrors cannot be adjusted obviously)
when the fuse is in, the seats can be moved manually, but the memory features aren't working... so i'm suspecting its the actual memory switch which is causing the leak,
can anyone suggest as to how i can pinpoint where exactly its shortening. its drawing 2AMPs continuously, correct me if i'm wrong but thats too little for the electric seat motors?
holden suspects ( and aren't sure) that its the Memory seat module ($ 700 to supply ) they're suggesting i start with replacing that.... they're laughing if they think i'm jsut going to fork out the dosh for their guess.
any ideas would help.
cheers
cheers
