VZ 05 wont cank over...ecu, bcm, sensors? PLZ HELP
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by mx_chik, Jan 16, 2011.
  1. mx_chik
    mx_chik New Member
    brisbane
    253 hilux
    Hey guys i have read through other threads on here to try sorting out my issue but each one is a little different to my situation so thought id list the specifics.
    Its an 05 VZ as stated (auto), last night we went to go out for dinner and it wouldnt start. Just ticking at the stater motor no cranking. It was first claiming an ABS fault, then later, low fuel, service and SRS airbags. i have checked terminals, battery, starter wires and reset the ecu. since reseting, the ignition wont even turn on so i cant even system check to get an error. Has anyone experienced this before please help!!
  2. impulsive
    impulsive Alloytec Racing
    Brisbane, QLD
    VZ Alloytec
    Dead battery... Replace it you should be fine. Ticking at the starter motors usually tells me this
  3. richardpalinkas
    richardpalinkas Blown Alloytec
    Gold Coast
    Raptor Impulse VZ SV6
    all the faults appearing also tells a dead battery. my battery went and said abs fault a week before it died
  4. db_notso
    db_notso diagnostic technician...
    sunshine coast, qld
    vt v6, mods(susp brakesetc...)
    +1 dead battery
    the abs module doesnt have enough voltage to wake up and so sets codes in ipc "abs fault"
    light goes out if jump start if battery fault as altenator takes over the supply job of voltage
    else worst case scenario intermittant no clicking and no start is earth inside ECM needing new engine control module
    replace battery check if any lights on then repost here!~
  5. impulsive
    Brisbane, QLD
    VZ Alloytec
    I can get batteries for $40
  6. Chrain01
    Chrain01 New Member
    VZ Commodore V6
    Had same issues, had new battery as old one was stuffed but all faults came after new battery was installed, just came from Holden and after two days they found the ipc not communicating correctly and throwing the same codes abs srs low fuel etc .. might help someone with similar faults
