madmatt2006
- Jan 6, 2008
- 31
- 7
- 8
- Soarer 1jzgtt VH commodore VZ svz
Hi Guy's
Still trying to work out this VZ ute after engine swap. I have got the motor running but I have issues with right side inlet cam sensor wiring or possibly something else is interfering with it!
So here is what I have to do to get it to start. plugin all four cam sensors, turn engine over is pops and crackles no starting. Next unplug all cam sensors turn engine over it starts! (runs rough). Next I plugin left exhaust cam sensor ( while running ) then I plugin left inlet cam sensor engine runs smother. Next I plugin right exhaust cam sensor ( while running ) engine start running real good smooth, then I plugin right inlet cam sensor kills engine stops running!
things I have tried
1. new cam sensor on right inlet. no change still have to do all the stuff to get it running.
2. tried 2 ECU's and BCM same result!
I'm going to check wires see picture
What else could be the cause please help this has me stuffed!
things I have tried
