PrincessPet
- Aug 15, 2018
- 4
- 0
- 1
- Age
- 42
- Location
- Western Australia
- VZ Commodore V6 Alloytec
OMG where do I start? So the VZ ute had an oil leak, I traced it to the timing cover and since it was such a big job I booked it in at our mechanic to replace. When I got there, the water pump **** itself so that needed replacing as after I degreased the engine bay, it was spewing coolant out. So half way through, he's like the seal from the waterpump and the engine bay is about to fail so needed to do that to. 10 days later I picked up the car and went straight back as it was running rough as ****. Turns out they only replaced the pleminum gaskets, not the manifold gasket like he said he would. Replaced manifold gasket and yay, engine now has compression but..... There is this really fucked up wierd vibration coming from the left side of the engine bay only when the car is in motion. Like, can't be the normal culprits as it runs like a kitten at idle..... So he's now had it for another 10 ******* days and I don't even think he's looked at it so I'm planning on picking it up and having a look myself. Any ideas?
06 VZ Commodore Ute, 3.6lt Alloytec 4sp Auto
