VZ 6.0LT Exhaust set up
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by petern64, Sep 8, 2012.
  1. petern64
    petern64 Member
    seven hills nsw
    vz ss 6lt
    is anybodoy running Genie extractors with MangaFlow cats and a 2 1/2 mild steel RedBack exhaust sytem??
    I am fitting this set up to my 06 SS sedan and was curious as to what it will sound and go like
    Pete
  2. Kiddo
    Kiddo You're serious bro?!
    Mitsubishi Colt
    With all the different exhaust options/brands, is hard to find someone with the EXACT same setup. And even if you did, the sound may still differ.
    But let us know how it turns out!!
  3. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    You're putting a Redback system on a 6L? Is that the system with the kiss pipe just after the flanges? I've seen them glow red because of the restriction they create.
  4. petern64
    petern64 Member
    seven hills nsw
    vz ss 6lt
    Once fitted I'll let you all know what I think, I'll take a look at the kiss pipe section after a few days on the car and look at heat burns,
    thanks for the feed back ,
    Pete
