Vz airbag
Albie63
60
Nsw
Vz thunder
Hi there
I have a 06 vz thunder Ute that the srs light is on done a scan with my scan tool and is coming up with 999.0 ohm to passenger air bag .
Only thing is the Ute is not fitted with a passenger airbag
So a bit baffled as to where to go next?
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Hi there
What scan tool are you using?
Albie63
60
Nsw
Vz thunder
A vident I link 400 loaded with holden software, also had a friend with a tech 2 and same result
Lex
Geelong Victoria
Has the module been changed recently?
I have the vident i400 too. Not a bad unit for the price.
Has the cluster been changed recently?
Albie63
60
Nsw
Vz thunder
I’m not sure we bought the Ute second hand for our son has had engine and gearbox change though
The module under the centre console looks original
Albie63
60
Nsw
Vz thunder
Not that I’m aware of I did buy another one to try but no different
lout
61
Langwarrin Victoria
are you sure the thunder does not have passenger airbag
Albie63
60
Nsw
Vz thunder
Yep pulled all the dash out today and no wiring and no airbag under the oval section of the dash
