VZ alloy tech v6 oil filter housing broken
Fu Manchu
WA.
Bunnings Ozito one will do the job for cheap.
BowTie
Jindabyne
Vr vt
Oh man.
I'd love to see what Ultratune would quote for this.
We could have a sweepstakes on who guesses the closest.
I reckon 4k.
Fu Manchu
WA.
I think you are right if you have glanced at the procedure would it be possible for you to post the procedure here with a link or something. Thank you for trying to help.
I’d have to go digging through again.
robherron
75
Crows Nest
VE
Has anyone had this problem and how did they get the cover off? It seems to have been tightened on with a rattle gun. Any help would be greatly appreciated. View attachment 218410View attachment 218410
Stillson sounds like the best idea to me or the tap around the rim with a sharp screwdriver or chisel .
It may have been tightened so hard because it was leaking and they do leak if people forget to change the large "O" ring when they change the filter .
gossie
Gold Coast.
VE International 3.6L
I did suggest the chisel early on, and this getting this off has been going on far too long now.
Is it off OP?
As mentioned always use the new O ring and it will not leak, and you never need to pull it down tight.
Just as it starts to nip is fine.
But of course check check check regularly.
Big Red VF-SII Go-kart
I love puddles.
Darwin NT
VFII MY17 SV6 (LFX) Sportwagon (SOLD)
Get yourself a traditional oil filter wrench, and a strip of non-slip rubber.
for example —>
Place and secure the non-slip rubber around the oil filter housing cap, then place the filter wrench over it, progressively tightening it, and give the cap a twist until it loosens. Do not bang the cap or put anything like WD-40 on it as it will affect the threads.
The cap is never ever secured with a rattle gun. Just a ring spanner and a modicum of tightening. Replacement caps are available.
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
Is it off OP?
While I fully understand what you mean by chiseling it off and agree it is the best method, I am sure most people would not understand until shown how to do it.
And Big Red Go Kart the filter wrench will not work, way too flimsy
Best bet is stillsons or foot prints but not easy to use in that position
wannaeatyourbrains
52
Mecca
VZ Executive
For some reason, I am so keen to know if it came off. I almost wish mine would seize on there so I could have a go.
